Mazda Audio \  audio help!!
audio help!!
Mazda Audio Mazda Tech
views 1154
replies 6
following 7
mazdawgydawg   +1y
Hey guys, i need to know a few things soo i can install my stereo, first which wires go with which? theres nowhere to put a wireing kit seeing how there was already a deck in it, how do you run and where do you run the wires to the amp, and subs? thanks guys,
-Dj
sierrax   +1y
Not to be a dick but if your asking these questions, you should have someone install it for you. Most likely you'll blow something up costing you more money than the install. If not do some research on how to do it. Try these links.
This site is the cats ass on 12v products. You might have to search a bit but it is all here.
sncflow   +1y
when you pull the stereo out is there wires that lead to a clip that then runs into the dash? if it is a stock radio than the harness into the stock radio is the harness you just have to get a mazda b wiring harness. unless u already knew all what then im sorry. post back and ill try and help
crazymikey   +1y
Just touch wires together until something works. Watch out for sparks.
immortal1 (linn)   +1y
^ works fine, just stock up on fuses
maztang (ryan)   +1y
alright bro, first off, get a test light. pull your radio out of its location. find the ignition wire (the red wire on after market radios) or you can check by turning the ignition to the on position and seeing which wire turns on the test light, when you turn the key to the off position and the test light goes off than you found your iginition wire. run a wire from it to the remote wire on the amp. you will run a wire straight from your battery to the 12v source on the amp with a fuse no further away than 2 ft from the battery, you also want the fuse to be equal to + or - 5 amps of the total of amps combined of the fuses. what i am trying to say if you have an amp with 2 fuses equaling 60 amps than you want a fuse coming off your battery that equals anywhere from 55 to 65 amps. then just ground the amp and run you speaker wires.
i hope this helps and doesn't confuse you. later.
mazdamn   +1y
the guy who did the BCAE1.com is a personal friend of mine. His name is Perry Babin. Hes my amp repairman. He also has his own line of amps. Check them out. I live 20 minutes from him, and I go to him often with peoples fried amps, he's DAMN good.
