Mazda Audio \  Wiring A Tach?
Wiring A Tach?
Mazda Audio Mazda Tech
views 1375
replies 8
following 8
pepehn   +1y
Hey everyone, Was interested in putting my autogage tach in my truck..Need a bit of help.
It has 4 Wires,
Red -Switched 12V on Fuse block
Black - Ground
Green - Neg. Coil
White -12V Dash Lighting
I pulled my Cigarette lighter since i don't smoke, and was thinking of using the black wire as a ground, and if possible connect the red and white wire to the positive end.
Would that work ok?
Where abouts on the coil does the green wire connect (anyone have a picture?) and what should i use to connect it..(ring terminal..?..splice into wire?)
How do you have yours wired up? thanks a mil.
thetornado   +1y
i used to have a seperate tach, made by sunpro i believe.
Red - i connected to the fuse box on a extra fuse spot.
Black - Grounded to the firewall
Green - to the coil
White - spliced into the dash lights going to my air controls
that help?
brokentoyz   +1y
remeber the green wire goes to the negitive side of the tach or the tach wont work
whiteyb22   +1y
at teh coil there should be a white wire if you ahev a fue injected truck connect the signal wire to that
it took me about 15 mins to instal it in my truck
golden dragon   +1y
Red to Fuse Panel
Black to firewall
Green to coil neg
White to dash lights
I connected to the switched side of the dimmer rheostat so the tach light will dim with the dash lites.
and I used a fork terminal on the coil so I wouldn't have to take the nut off all the way.
Happy wiring!
all4show33   +1y
I hooked up a tach in my truck and it is only reading half. Do i need a tach adapter? has anyone else had this problem?
badchicn (rick)   +1y
On some tachs there is a switch for four cyl/6cyl/8cyl. I suspect yours is in 8 cyl mode.
slammed83mazda   +1y
I have been thinking about putting a small tach in my truck, just to be safe. I really like playing the whole shift thing by ear.
Thanks for the info guys.
all4show33   +1y
yeah i bought a little sunpro, and there was a switch on it. It was located behind the mounting bracket so i didnt see it. God i feel stupid........lol anyways it works fine now.
