Mazda Audio \  RE audio?
RE audio?
Mazda Audio Mazda Tech
views 2298
replies 15
following 7
elbine69   +1y
Anyone have any experience with these subs? Im thinking of getting these subs(info about them is down below) for a lil bump in the daily. Also I have a 400w jensen 4 channel amp, would that be fine for these subs or should I find a different amp?
RE SERIES
Product Dimension
8â€
mazdamn   +1y
RE is good stuff. I wouldnt put a Jensen on them.
bagged_91_2600i   +1y
ya re are preety badd azzz i had a buddy with 2 12s that pounded, and agreed dont put a jensen amp, espically not a 4 channel
fantomrush   +1y
yeah replace that jenson amp with something with a little more kick. RE subs are awesome, but that jenson amp isn't going to do them much justice.
elbine69   +1y
What would be a good amp for them then?
2slow5.0   +1y
anything of name brand.
the amp i had in mind was the fosgate 360a2, older amps but would fit the subs perfectly.
found one on ebay.
mazdamn   +1y
i got an orion 2100 HCCA that can run 1/4 ohm mono for hours.....hehe, wanna see how far those REs can move?
f n lo   +1y
i got 2 15'' RE HCs in my rodeo, soon to be in the mazda, with a hifonics collusus II amp, so each is seeing about 1600wrms at 2 ohms, daily.... the box is tuned to 35 hz, they move EVERYTHING,...
also check out also a VERY solid sub, for a decent price...
for an amp check out
f n lo   +1y
if you dont mind me asking what amp could possibly run at 1/4 ohm daily???????
elbine69   +1y
I have a question, when you guys talk about that amp can run at 1/4 ohm does that have to do with how the sub is wired or what? and am I right in assuming that the lower the ohms the more power the sub is getting?
