Mazda Audio \  errr!!! 2ND speedometer cable broken!!!!!!
Mazda Audio Mazda Tech
views 847
replies 5
toyorotor   +1y
this is the second cable i have installed and its broken in less than a mile of driving..... is there something i'm doing wrong??? or maybe something getting stuck in the transmission??? please help these cables are not eazy to come by......
pont   +1y
Have you done the nontach to tach conversion using stock mazda parts If so did you move the cable out of the little center hole to the left. If not then there is your problem. If you have not done the tach swap then I don't know what to tell yea
toyorotor   +1y
no i have not done that swap.... cause the truck came with the tach.....
mazdatweaker   +1y
post deleted
Post was last edited on May 12, 2009 03:05. This post has been edited 1 times.
toyorotor   +1y
MazdaTweaker:
this was a used cable i got with the housing, the first one broke like 5" from the speedometer, the second one i havent taken off yet......
should i just buy a new cable? or is it something in the transmission that is getting stuck?.....
hocbj23   +1y
On the tranny side there is a smallish green drive gear that causes the speedo to turn.Be sure that gear moves freely and put a dab of white lithium grease on the teeth when u put cable in.Be sure gear seats properly.BJ
