Mazda Audio \  i need help with speakers
Mazda Audio Mazda Tech
views 2233
replies 14
jokerloco018   +1y
ma audio hk120 or aplhasonik psw812 what do you guys think is better?
mazdachick   +1y
I Dont Know Much About Speakers, But Doesnt A Better Speaker Have A Higher Watt Rating? I Know You Have To Consider Your Amp Into It.
slammedyota91   +1y
not always does a better speaker have a higher watt rating, shit speakers are rated 200 watts or for subs 1000 watts doesnt mean they can really handle them, look at THD% lower the better.. also frequency responce... and voice coil size.. all the cmoponents.. of the speaker.. every little bit counts
jokerloco018   +1y
the links that i posted have all the specs on them i was kinda wondering if someone can look at them and tell me what they thought my bro says go with alpha and i say ma audio so you guys are the tie breakers
fanninator   +1y
me personally... would go with ma. i hoe you are ext cab bacause these are pretty deep man. -bf
jokerloco018   +1y
yes i do have a cab plus i should of said that too.
slammedyota91   +1y
well the ma audio look tight and "handle more power" but they dont give a sensitivy rating on it, the alphasonik does its 92db 1 watt 1 volt, which is average most subs are between 89-93db, also has a 2.5" voice coil (dual) and the MA doesnt say how big it is, if it were me itd be a tough decision i like ma audio a lot, but wihtout knowing specs.. hard to say
jokerloco018   +1y
see thats my problem
slammedyota91   +1y
i would go with the alpha's the are 900 rms which is way more than the ma i just looked ma power rating was max
