Mazda Audio \  Remote Starters
Remote Starters
Mazda Audio Mazda Tech
views 1113
replies 7
following 5
mazcanada   +1y
I need help here i am trying to installl a Prostart remote starter in my 1990 b2200. Has anyne dones it and can they help me with what wires re for with because the wirning dirgram i got for the truck is the shits.
all4show33   +1y
is it 5spd or auto
all4show33   +1y
hope this should help
1990 Mazda B 2200, B 2600 DirectWire 2.0 Vehicle Information
All Products
Item Wire Color Polarity Wire Location
12 Volts black + ignition harness
Second 12 Volts
Starter black/yellow + ignition harness
Second Starter
Ignition black/white + ignition harness
Second Ignition black/red + ignition harness
Third Ignition
Accessory blue + ignition harness
Second Accessory
Third Accessory
Keysense
Data Bus
Can Bus High
Can Bus Low
Can Bus Sw
Power Lock
Power Unlock
Lock Motor
Driver Unlock Motor
Passenger Unlock Motor
Parking Lights (-)
Parking Lights (+) red/black drivers kick panel
Hazards
Turn Signal (Left)
Turn Signal (Right)
Headlight red/black + light switch
AutoLights
Reverse Light
Left Front Door Trigger red/yellow - drivers kick panel
Right Front Door Trigger
Left Rear Door Trigger
Right Rear Door Trigger
Dome Supervision
Trunk/Hatch Pin
Rear Glass Pin
Hood Pin
Trunk/Hatch Release
Trunk Release Motor
Fuel Door Release
Power Sliding Door (Left)
Power Sliding Door (Right)
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Trunk Alarm Shunt
Tachometer white ac ignition coil
Wait to Start
Neutral Safety
Clutch Pedal
Fuel Pump
Rear Defroster
Mirror Defroster
Left Front Heated Seat
Right Front Heated Seat
Speed Sense
Brake Wire white/green + brake switch
Parking Brake
Horn Trigger green/yellow - steering column
high current ground use relay.
Wipers blue/white + wiper switch
Left Front Window (Up/Down)
Right Front Window (Up/Down)
Left Rear Window (Up/Down)
Right Rear Window (Up/Down)
Sun Roof (Open/Close)
Sun Roof (Limit/Close)
Memory Seat 1
Memory Seat 2
Memory Seat 3
Radio 12V
Radio Ground
Radio Ignition
Radio Illumination
Factory Amp Turn-on
Power Antenna
Left Front Speaker (+/-)
Right Front Speaker (+/-)
Left Rear Speaker (+/-)
Right Rear Speaker (+/-)
Center Channel (+/-)
Subwoofer (+/-)
Aux. Audio Input Left (+/-)
Aux. Audio Input Right (+/-)
RSE Video (+/-)
RSE Audio Left (+/-)
RSE Audio Right (+/-)
Satellite Radio 12 Volts
Satellite Radio Ground
Satellite Radio Ignition
Satellite Radio Antenna
Satellite Audio Left (+/-)
Satellite Audio Right (+/-)
Item Size Depth Location
Headunit
Left Front Speaker
Left Front Tweeter
Right Front Speaker
Right Front Tweeter
Left Rear Speaker
Left Rear Tweeter
Right Rear Speaker
Right Rear Tweeter
Center Channel
Subwoofer
Left Front Headrest
Right Front Headrest
Left Rear Headrest
Right Rear Headrest
Satellite Radio Tuner
Smart Starter Kill Relay
Relay Type:
Part #:
OE Relay Part #:
n/a
n/a
n/a
Notes:
n/a
Alternate Part Notes:
n/a
Immobilizer Bypass Module
Required:
Type:
Part #:
Alternate Part #'s:
No
N/A
N/A
toddluck   +1y
i hope its auto
midnightmike   +1y
theres nothing wrong with putting a remote starter in a 5speed
ive been doing remote starters for nine years and ive never at a problem
let me know if u need any help
toddluck   +1y
i guess i was just saying i dont trust myself with a stick and remote start...lol
mazcanada   +1y
yes it auto, and i will try this, it is much better than what i got
thanks
mullet   +1y
are you still needing info?
and toddluck I had a remote start on several of my 5spd trucks. I just did a kill switch bracket around the base of the shifter so if it was in gear it disabled the remote start. Just in case I was retarted enough to keep it in gear.
