Mazda Audio \  86 b2000 blinkers not working
Mazda Audio Mazda Tech
views 945
replies 2
following 2
bond343   +1y
hey all,
i have an 86 b2000, and this is the deal- the hazards lights flash in the rear, but not in the front, and the blinkers do not even work at all. i know that lights in the front are good bc they come on when the lights are on.
i believe my flasher supports the hazards and the blinkers, but many folks have said there should be two different flashers. i dont have my buzzer hooked up, but hooking it up makes no dif, i have lubed the switch to no avail.
any suggestions are greatly appreciated
thanks
bond343   +1y
i fixed it, my hazard switch was the problem. when turning off the hazard switch, it would get stuck, causing the blinkers not to work. so what i did was turn off my hazard switch "with avengance" and then my blinkers would work, but if i did not turn the hazards off "with avengence" then the blinkers would not work. so i lubed the crap out of it and now it works normally again
zaccutt   +1y
Nice. I had pretty much the exact same problem. I never did figure out what it was they just started working again, maybe it was the same thing as yours...
Zac
