Mazda Audio \  cd player help
cd player help
Mazda Audio Mazda Tech
views 622
replies 6
effdbmx1   +1y
ok so i hooked a cd player and it turns on and everything works. but for some reason the speakers dont work. i hooked up the speakers directly to the deck (not through the truck wiring) and they still didn't work. when i turned the volume up all the way, i could kinda here the music but thats with my ear next to the speaker. i know the speakers work cuz there new. i'm thinking its the head unit. but i dont know. i just took it out of my other car and it was working fine in the other car. its a couple months old. do you guys think its the head unit?
dropndragmazda   +1y
Sounds like the outputs are burnt out, or theres a speaker wire touching another!
What kinda deck is it? Pioneers are bad for burning up the outputs..
effdbmx1   +1y
i'm not sure what kind of deck it is. what do you mean by outputs buring out? like inside the deck? and i know the wires aren't touching. i'll just have to fool around with it some more and after it pisses me off enough i'll just buy a cheap one off craigslist just to see if its the deck or not.
dropndragmazda   +1y
Yeah there inside the deck, u can use an amp and use the rca jacks!
But it's just as cheap to buy another deck!
kirk   +1y
It sounds like either a short, or you burned out the powered amp in the head unit. Double check your wiring. Pull the head unit out, and run a short wire right to a speaker in your lap. If it wont sound off, its the head unit. Are you sure your speakers are good? For sure, for sure?
effdbmx1   +1y
ya thats what i did and the speakers barely made any sounds at full volume. and i know that they are good because they were working in another car. i also took speakers out of my mom's volvo and tried those and it still did the same thing. its weird that its the head unit cuz i was working right before i took it out of another car. but i guess i'll just get a new deck. thanks
night rider   +1y
i agree. i had this happen in my truck when i first put the speakers in the door. all i did was cut a hole out and screw the speakers directly into the door. when i turned the unit on i couldnt hear anything unless i turned it all the way up and even then it was hardly anything. i unscrewed the speaker from the door and almost went deaf.
