Mazda Audio \  Stereo Problem...
Stereo Problem...
Mazda Audio Mazda Tech
views 808
replies 7
following 6
madmazda   +1y
Hey guys... I've got an issue with my, Stereo in my 4x4 Jimmy... I'm getting static in my speakers when i apply my brakes... only sometimes... I've running a 2 amps... One 4Ch for speakers, & One for my subs... I was thinking possible bad ground?? on Amp?.. Or Deck?... Doesn't happen when im parked. Or driving, on when i apply the brakes...
90-b22dawg [andrew]   +1y
stop-stopping just kidding.... have no idea.... sounds very strange!!
hex0rz   +1y
Do you have ABS? If so, there might be some sort of conflict going on with the 2.
...say they are too close or something.
Other then that, I think your just crazy!
madmazda   +1y
Yea, i got ABS, although the ABS sensor is messed up...But Conflict with the 2, i've never heard that before... Hmm...
jester   +1y
Sounds like a bad ground, or funny enough I had the same problem with a truck I bought. Every time the brake was pushed it pinched the RCA cable that was run up there. Sometimes it's just the silly little stuff
nonamedsomebody   +1y
How are your wires ran are they ran next to the abs system at all you may be getting 'cross talk' where interference jumps between the abs system and your stereo system
devb22   +1y
^^Exactly!
Most likely your problem is "cross talk" somewhere in the wiring!
But double check your ground too, make sure its no longer than 3'
Dev
madmazda   +1y
I'll check into that in the next few days, Thanks guys.
