honda seats
honda seats
mazdabon2nd
i know some one has done this before. do i have to drill new holes? or make a custom bracket?
thanks
-Mike
T{
texaslowlife {john}
I used the seat brackets off the stock mazda seats and put them on the honda seats i used 93 civic seat. cut the brackets off the honda the frount bolt up i drilled new holes in the back of the honda seats the wholes are a little off you got to squeeze them in but they work i know its harder than it sounds i done it make sure you use grade 8 bolts the all others broke. hope it works out for you good luck if you got any more questions just ask.
mazdabon2nd
i had bench seats so did you only put one from the mazda? i think im going to cut the hump put that the original seats were attached to and put square tubing.
cyclitis
The front two wholes of each seat just had to be widened to match up.
I used aluminum blocks about an inch and a half high in the back. Made to holes in the block, one to match the hole in the floor and one to match the seat.
I found the seats were angled back anyway, so this made them level.
If you want I can send you a picture of them.
mazdabon2nd
can you send me pics?? it would help me out alot
cyclitis
ya sorry about the late reply..kinda forgot my bad
I'll take pics tomorrow
