Mazda Audio \  PLEASE HELP!!! Electric Draw. '91 b2200 xcab
Mazda Audio Mazda Tech
views 1188
replies 11
following 7
rreyna   +1y
im experiencing an electric draw. It will kill the battery if you leave the fuse in all night. I do know that the draw is on the fuse that's under the hood, It works the constant hot to radio, dash clock, dash lights, dome lights, and running lights. I know this because if pull that fuse i experience no problems besides the obvious. Whatever it is its on the fuse under the hood. Any help would be appreciated.
P.S. I just signed up a couple of days and im amazed as to the info on this site. Its been 8+ years since ive built a mini and had no idea so many still did. Last mini was '87 S10 Ody dropped on "18's back in 1996. It feels good to be back.
90-b22dawg [andrew]   +1y
do you have a stereo system?
rreyna   +1y
just replaced factory unit with a cd player hoping that may fix it. well see in the morning.
hope that fixes your problem... if not let us know... im sure we can think of other things it could be....
rreyna   +1y
cranked right up this morning. well see over acouple of days. thanks for the input guys.
toddluck   +1y
mine does the same thing if i let it sit for three days
crazymikey   +1y
Was it doing this with the aftermarket deck installed or with the factory one?
elbine69   +1y
Sounds like it was doing it with the factory deck.
sparage   +1y
I moved my battery to the bed and am having trouble getting enough power to everything. For example radio is on then turn the light on and the radio will go off, or when starting it is like the battery is weak. Also the door poppers pop the door open fine if it is running but if not then i have to push in on the door then hit it. Altenator is a year old took it off the other day and it tested good also just replaced the battery, and the starter is almost new. Any ideas??
toddluck   +1y
battery cables...also sounds like you have a very bad ground somewhere
