Switched wire not working?
ledevil@msn.com's avatar
ledevil's avatar
ledevil
So I got my truck with a aftermarket Tach in it. The Tach was wired to the radio switched power source. I took out the Tachometer and now my switched wire for my Radio doesn't work? It's the Blue/Red wire if I'm not mistaken. But I get no power from it or any other wire under there when the key is in the on position except the constant power source. Is there something I should look for to get this wire to work again other then the fuse?
dome light fuse would be my guess
midnightmike's avatar
midnightmike
no the dome light is on constant power
the fuse i belive you should be looking for is the RADIO fuse
room
Post was last edited on Aug 09, 2008 07:28. Edited 1 time.
ledevil's avatar
ledevil
ok this sounds dumb but there isn't a Radio fuse labeled on my fuse block. I know what a NEWB but I looked and there isn't one
slammedyota91's avatar
slammedyota91
under the dash fuse panel, yes there is
90-b22dawg [andrew]'s avatar
90-b22dawg [andrew]
theres also one labeled ROOM
ledevil's avatar
ledevil
I have the room one just not one labeled Radio
89mazdawg(daniel)'s avatar
89mazdawg(daniel)
mine doesn't have a radio one either, but i have the room one
ledevil's avatar
ledevil
So I took out ALL my fuses and everyone of them was good! If they looked any kind of old I replaced them....So the switched wire still doesn't work :/
