Mazda Audio \  bypass the "open door button switch"
Mazda Audio Mazda Tech
views 1329
replies 12
following 7
bodied b2600zx (josh)   +1y
You know that lil button switch on the bottom corner of thr door that turns the interior lights on when the door is open??? How can i bypass that button. So it never turns the lights on. I want to put door poppers right there and the switch is in the way.. Thanks!
mazdawg(mikey)   +1y
you can take them out and unplug them, that way it doesnt see a ground. when they open, they send a ground signal to the lighting completing the circuit and making the lights come on.
baggd   +1y
^^^He says he isn't smart.......
ya i saw that when i took it out, thanks man! I got the poppers n solenoids installed and the driver door works great, i have to hit the button twice to get the pass door to pop, i think there may be too much slack in the line, i dont know, i'll check it out tomor, i gotta go to work
mosher   +1y
i wouldn't have removed them or i would relocate them b.c if you install or have an alarm its not going work
whys that??
toddluck   +1y
because they activate your alarm when the door is open...just relocate them
hungry&fat   +1y
or just install aftermarket pin switch somewhere else like in the door jam area around the hinges.
mazdawg(mikey)   +1y
yeah in alarm terms thats the door trigger. plus you wont have any dome lights and that sux.
dragn37   +1y
mine makes the LOUD high pitch noise everytime the door opens, so i just loosend up the ground screw, and problem solved!
