carpet?
rjrdist@pclnet.net's avatar
carpet?
same_me's avatar
same_me
what can I look forward to finding when I pull my carpet out of my truck. My carpet is ruined so I'm planning on pulling it out. What I'm wondering is there going to be insulation glued to the floor? Wires run under it? What? I know this is kinda of a stupid question but I like to know what I'm getting into before I tear into something. If it's gonna be just basically the metal floor then I'll probably go without carpet for awhile. Let me know guys....
tre5
There is backing that is glued to the back of the carpet. Then there is a rubber mat that has backing glued to the back of it also. They will come up seperatly. Some of it will probably be stuck to the floor.
mazdawg(mikey)'s avatar
mazdawg(mikey)
like he said plus the rubber padding is stuck under some parts of the truck like the heater core and the clutch and brake assembly that has to be removed, or just cut the padding around them.
same_me's avatar
same_me
thanks for the info guys. Theres a certain look im going for on it and I'd like to go without the carpet. I'll snatch it out and see what it looks like and see if I want to put something back in it or if I want to run it without carpet.
roger26i's avatar
roger26i
hey buddy fyi if you are ever looking for carpet or a rubber floor check out jcwhitney.com they are super cheep too good luck
I
izulowtoo
there used to be somebody on here that sold carpet kits.
i think it was slammedyota but not sure.
if i remember correct there was like four choices or something.
91b2200(cody)'s avatar
91b2200(cody)
to remove my single cab carpet i just cut it by the foot pedals and removed kick plates but .. you'll seee it all when ya get there tho
rutter0907
if anyone needs carpet my friend sells ACC carpet kits. these are bought dirrectly from acc not a discount store bought stuff. ACC stands for auto custom carpets.he can take credit cards and have carpet drop shipped directly to your resedence. let me know thanks.mike
big rick's avatar
big rick
I thought about painting my floors for a while, but when I pulled the carpet it was way to loud inside. Try it ...you'll see!
crazymikey's avatar
crazymikey
Pulling the carpet is simple. As most guys say,just cut it around the heater core and then zip tie it back after.
