help with head unit
justafriendtoyou@cox.net's avatar
help with head unit
seaglass's avatar
seaglass
so i have a prob with my head unit, the acc wire only works when the lights are on.. so i guess that the wire has been crossed somewhere anyone how and where to fix this?
also the memory on my head unit wont work when hooked up to the acc (believe it has to do with the wires as mentioned above) but would i need to hook it up to the constant anyway or would the acc be fine for that
any input would help thanks!
sosatheshark's avatar
sosatheshark
get a voltmeter first ,hook up ground ,then take acc to wire that shows hot when key is turned to acc,and then power to constant 12v sounds like wires are messed up
seaglass's avatar
seaglass
well see that the thing, i only wire left is the Illumination (BLUE/WHITE) wire and the rest are speakers and grounds soo i guessin i need to just run a wire from the ign fuse in the fuse box?
mazdawg(mikey)'s avatar
mazdawg(mikey)
Battery BLUE/RED (+) RADIO HARNESS
Accesory RED/BLACK (+) RADIO HARNESS
Ground N/A
Illumination BLUE/WHITE (+) RADIO HARNESS
Dimmer N/A
LF Speaker (+) BLUE/RED
LF Speaker (-) BLUE/YELLOW
RF Speaker (+) BLUE
RF Speaker (-) BLUE/WHITE
LR Speaker (+) BLUE/RED
LR Speaker (-) BLUE/GREEN
RR Speaker (+) BLUE/WHITE
RR Speaker (-) BLUE/GREEN
dvsdev
Err you've hooked your power into the dimmer circuit of the trucks wiring, it's designed to dim the stereo at night time so it's not so bright.
Just have a look for another live wire and you'll be fine, try and think of something that's always got power when the keys off and that will have a live wire going to it if you can't find one in the original loom.
