Page 1 of 4
S10 Suspension \  electrical problem
electrical problem
S10 Suspension S10 Tech
views 5524
replies 34
onesicks104me619   +1y
okay every one i need some help..... i have 2 DSC 1500 putting air into 2-5 gallon tanks.... i have my power ran from the battery.... back to my bed... which runs into a 100 watt fuse.... that in turn goes into my relays and then the wiring for the relays is ran correctly.... my compressor's are ran off of a toggle switch that i can turn on and off...... i have an adjustable pressure switch....... now heres the deal........ i fried my relays and rewired them...... follow wiring diagram....... made sure all of my wires are ran to the correct prong and to the proper place... i am not getting anything to my compressors to air it up...... i can jump a wire from the battery to the toggle switch and it will turn on........ does anyone have a clue or maybe point me in the right direction as to what to look for now or what to replace.......
dragginncrds   +1y
is the hot for ur toggle switch goin to the relay or to the compressor...
the toggle switch wire runs to the compressor side of the relay and then a power wire to the battery........
maz89   +1y
almost sounds like the toggle switch is shot, but you should be able to tell that by just the feel of the switch........ bust out a test light and go from one connection to another and see where the power is not following through......
aight thanks bro i will check it out.......
maz89   +1y
If you find the problem or have more questions, post'em up, ya got me wanting to know what the problem is too lol
aight imma look at it on friday night or sunday morning.... being active duty military you dont have too much time to your self...... and i have to work this weekend
maz89   +1y
damnit boy!
what was that for? actually imma going to go to AVS up in fresno today and pick up a new pressure switch and a new toggle switch...... so i will know tonight what the problem is and i will post it once i figure it out...... im going to switch one out at a time ......
Well the S-Dime is back up and running..... i went to AVS and bought a new pressure switch..... hooked it all up...... omitted the toggle switch and re-ran a power wire that is only on when my ignition is on..... and wala........ it fuking worked........ Hells Yeah...... so well yeah i had to throw some sparks on the city streets....... haha pissed some neighbors off but oh fukin well they will get over just as fast as they got mad........ i will post some video of the spark show later on today....... thanks for all your inputs and helping me solve this problem.......
