blower speed switch
highroller0439@aol.com's avatar
blower speed switch
89mazdalade's avatar
89mazdalade
on my mazda b2200 everything works when i got it just all of a sudden the first 2 lower speeds stopped working so i go to the junk yard and get another switch and replace it and it still does the same thing only the 2 high speeds work is this a common problem it has a brand new blower motor i was told there is a blower motor resistor what is that and what does it control i looked all over on my truck for it with no luck i also bought the hayes repair manual and it shows it with the blower motor but i dont see anything there just a vent tube can anyone help me out with this thanks
midnightmike's avatar
midnightmike
the problem your having is the risister, its on the heater box under the dash, it has a 4 pin plug on it, its held it with 2 phillips screws, i might be able to access it better if you pull out the glove box, i cant remember anymore
good luck!
beatmymini's avatar
beatmymini
i sounds like a wiring problem. just climb into the passenger seat and take a look at the connector on the motor and where the wires from the switch hook up. some thing might be loose or old and crap.
89mazdalade
thanks im gonna start on it now thanks again
89mazdalade
so i found it and yeah its no good one of the coil thing was broke so i guess thats why the lower speeds dont work anymore thanks for the help
89mazdalade
thats what it was went to advance and they had 1 in stock amazingly thats what it was thanks again for the help!!!
midnightmike
no prob man,
i had the same problem, but i just pull all the heatr shit out lol, now the problem dosent exsist
