My Sub Box!!
My Sub Box!!
mazdadropped
Not complete but its starting to look like 1 .
Getting 3/4" plywood and gunna make it thicker and stronger .
Gunna put 2 12" orions in.
Photos -
heavenly_blade101's avatar
heavenly_blade101
nice, what kind of music are you into? 12's are best for rap and dance, 10's or 8's are better for metal and rock. looks good though.
isaacstyles92's avatar
isaacstyles92
Cool build. Do you know exactly which subs you're putting in it?
90-b22dawg [andrew]'s avatar
90-b22dawg [andrew]
in my experence plywood isn't the best product to build a box with.... it flexes under high pressure.... get you some mfd medium density fiberboard and build you the same box then compair the two.... other then that the box looks good....
mazdadropped
the wood right now is mdf and the outside is going to be playwood or maybe mdf agian now sure but ima run 2 12" orion HCCA Subs
ticky
why plywood on the outside?
mazdawg(mikey)'s avatar
mazdawg(mikey)
i think its too tall and it doesnt fit. looks like you got a box from a friend and put it in. doesnt fit the truck at all.
hunterw's avatar
hunterw
this is more myth then it is truth. 8s really arent good for anything, except wow factor. and 15s and 18s can be just as accurate and play lower freqs then most 10s ad 12s on the market. its all about the tuning and size of the enclosure and how well it matches the woofers parameters. and some 10s can play lower then some 15s its all about tuning, box size (which go hand and hand) and quality of the woofer.
hunterw's avatar
hunterw
yeah mdf is much better to use then plywood for building sub encloures. if you could afford a nice birch id roll with that put a nice stain on it and it would look sweet. or carpet it. but plywood is a no no. but then again you are only reinforcing the box so it may be ok. wouldnt be my first choice though.
jimbeater's avatar
jimbeater
8"s make good midrange and full range woofers. good if you dont have space... have a couple tens in the back, put an 8 under each seat...lol
