Mazda Audio \  gauge clusterf***
gauge clusterf***
Mazda Audio Mazda Tech
views 1084
replies 8
bee.em.doubleyou   +1y
well, my speedo/odometer work. but my fuel gauges works only when there is under a 1/4 tank, and the temp gauge never registers up to where it should. is this common? any ideas?
tunameltman   +1y
on the fuel gauge its prolly the same problem as mine, the wires in the sending unit weren't making contact. As for the Temp gauge, mine still doesn't work, I've got a aftermarket temp gauge in mine.
okay sweet, can i get to the wires on the tank without taking the bed off? i know they are making a good connection at the cluster!
tunameltman   +1y
The easiest way is to pull the bed off unless you would rather drop the tank, which in my opinion is more of a pain. Hope that helps!
okay, thanks dudeski!
tunameltman   +1y
No problem man. Let me know how it goes!
for sure probably gonna go for the gold on it tomorrow
jimbeater   +1y
soak your bed bolts in wd 40 every day for a few days, then impact them off... mine sucked bad, but not too bad on my parts truck. be sure its the right size socket... hammer it on lol, dont strip... its a hard spot to cut/grind a bolt out of...
thanks for the tip. nice looking truck as well.
i'm lazy i need to get pics up of mine.
