Mazda Audio \  Installing window crank
Mazda Audio Mazda Tech
views 1048
replies 5
nevr2low93   +1y
Ok so when I got my '87 Mazda B2000 the drivers side window crank and the piece it bolts to was taken out to use on a 4x4 Mazda. I dont have the 1st clue even if i go buy all the parts how it goes back together? All i can see are 2 cables that I am guessing hook to it? Thanks
midnightmike   +1y
looks like your better off going to get a new window track assembly
baggd   +1y
^^Yeah, it looks like the previous owner ripped off only the crank part.
nevr2low93   +1y
ok thanks guys, i know its prob hard to explain but is there anyway to kinda tell me what to do when I get to the junkyard?
baddawg253   +1y
just take a 10 mm socket 3/8 rachet...should be 6 bolts for the regulator theres four around where the crank is..and two alil further back on the door thats the stationary run channel and if theres glass in the truck theres 2 10mm bolt onthe window mount tabs after you get all that undone pull it right out ... easy! im a auto glass tech. if you have anymore ?ns hit me up, .
nevr2low93   +1y
cool deal man thanks alot!
