New Toys!
New Toys!
heavenly_blade101 avatar
heavenly_blade101
Hey guys, I just picked up some new subs for 150$
imgs/heavenly_blade101/HPIM0823shq.jpg
Alpine Type-E 10"s
MTX TC3001 Class D monoblock 300watt rms
paparoach1983 avatar
paparoach1983
sweet i say make them fit and blast that shit.
heavenly_blade101
Just trying to figure out my best bets for a box now. STD cabs are a hassel to design boxes for. especially when your clueless.
airedout89 avatar
airedout89
just get a pre-fab truck box. No sense in wasting time building a box. Those subs wont need much space and they will still sound pretty good.
hunterw avatar
hunterw
i have a simple easy solution....just cut out the back of your cab and put the woofers in the bed facing fwd and seal up around them
baggedbmy93mazda avatar
baggedbmy93mazda
that was my first thought
heavenly_blade101
got the pieces cut to slap together a couple of 15x15 wedge boxes. 7 at the base 4 at the top. hopefully i can figure out why my full range speakers only crackle and pop. ground and power are both good, if i use the red RCA alone i get crackleing and poping, if i use the white, i get next to no sound.
90-b22dawg [andrew] avatar
90-b22dawg [andrew]
umm you need both rca's lol
heavenly_blade101
each rca is simply left or right channel. it just makes no sense that when i remove the red (left?) instead of only losing sound from that speaker my volume cuts to like 1/8th in the remaining speaker, and when i reconnect the red, and disconnect the white, i get more popping and crackling. I have cleaned my ground and power connections about 50 times, and double and tripple checked my speaker wire connections. i just have no idea wtf the problem is.
