poping sound
trplextommy253@hotmail.com's avatar
poping sound
baddawg253's avatar
baddawg253
ok so i just re did my sterio, i took my time actually and wired everything good i ran brand new wire for my 6.5s and my 6x9s and the sterio sounds good but when i hit my switches im getting a poping noise thru my speakers i thought it was cus i had my speaker wires next to my airride wires but i move them and it still dose it . i have the power for the deck tapped into its own fuse on the fuse block too...and ideas?
90-b22dawg [andrew]'s avatar
90-b22dawg [andrew]
where are you pulling power for the switches and valves?
baddawg253's avatar
baddawg253
my fusebox
90-b22dawg [andrew]
run a fused wire direct from the battery. should clear it up
baddawg253's avatar
baddawg253
ya im pretty sure thats what it is ...thankx!
baddawg253's avatar
baddawg253
nope wasnt it...still doin it lol ....
sounds like a ground loop
bigrob830
yeah sounds like a ground problem. first make sure your radio has a good ground some times the one on the radio harness (truck side) aren't that great, reground it to some support steel in the dash. also are you using a amp for your 6 1/2 and 6x9s? if so check that ground also make sure where ever you have it grounded you scrape off the paint, to get to bare metal.dont ground to a existing floor bolt cause they are not always good spot. They will get a ground but not the cleanest. If you are using a amp try grounding the RCA cables, this also works for engine-wine noise aka alternater whine. well hope you fix the problem.
baddawg253's avatar
baddawg253
ya , i have a amp for my highs..im ganna try doing a new ground
