running/dash lights
munkyballz_69@hotmail.com's avatar
running/dash lights
808hawaiian's avatar
808hawaiian
is there a relay for them? i keep blowing fuses. i havent found any loose grounds or exposed/crossed wires. they were working fine before. im really confused
808hawaiian
no help? seems like everytime i go over a bump the fuse blows
sounds like a pinched or rubbed wire
remove tail and all front turn and signal lights check maker sure none are pinched or rubbed to the wire
dzminiz's avatar
dzminiz
Just running lights? or headlights also
midnightmike's avatar
midnightmike
if you installed a deck in the truck, then check the wiring behind the radio, there is a red/black stripe wire that is for the dash and running lights that might be sitting loose and touching the steel framing behind the radio
808hawaiian
found out it was exactly that ^^^
