Billet Window Cranks
rabbit732
Is anyone using billet window cranks? I have an 87 b2200 but cannot find a pair of billet cranks that will fit the window splines?
I've tried the 7/16 and the 1/2" spline from Billet Specialties. I've even tried the 1/2" square spline and grinding down the splines.
Any help would be appreciated.
mazdaman82's avatar
mazdaman82
bump
im looking too i tryed the chevy crank and they dont work ether
porkchop69's avatar
porkchop69
The ones I got are universial which suck because the little Allen wrench always backs out
if u find some let me know too
eastwood's avatar
eastwood
I had a set on my 86 back in the early 90's. They were for a VW Beetle and they had a set screw to secure them. The only problem was that they would slip from time to time.
i have the ones with the allen wrench trick is LOC TITE
never comes loose
1hotdawg's avatar
1hotdawg
Was thinking the same thing. My steering wheel kept coming loose. Used Loc Tite and haven't had the problem again : )
rabbit732
Thanks for the info guys, but I can't even find a set that will slide onto the shaft. They are all too small. Other than the ones for a VW, what are the other brands you've found?
contact shavedmazda i bought mine from him
rabbit732
Is he on here?
dzminiz's avatar
dzminiz
I just had some universal ones, the set-screw ate up the splines pretty good.
Next set I guess I'll have to loctite them on.
