Deck wiring issues
Deck wiring issues
mytrukstilsux
So i went to wire in a deck for my 87 b2200 but only to find that somebody before me had messed around with the wiring. so instead of having the proper power wires i have a brown cable running into my relay box which was used to power the stock deck and i cant figure out which one the ignition power wire is..
what should i do? this is driving me crazy i need music for the road
dropped90(justin)'s avatar
dropped90(justin)
you put your volt meter on the other wires one by one to see which wire has power to it when the switch is on and loses power when you turn the switch off.
-justin
mytrukstilsux
i guess that would work.
the brown cable running from my relay box sparks when i ground it out. so theres definitely power to it but do you think thats enough to work as the 12v constant?
yes but make sure you fuse it and invest in a atleast a test light
mazdawg(mikey)'s avatar
mazdawg(mikey)
Battery BLUE/RED
Accesory RED/BLACK
Illumination BLUE/WHITE
Dimmer N/A
LF Speaker (+) BLUE/RED
LF Speaker (-) BLUE/YELLOW
RF Speaker (+) BLUE
RF Speaker (-) BLUE/WHITE
LR Speaker (+) BLUE/RED
LR Speaker (-) BLUE/GREEN
RR Speaker (+) BLUE/WHITE
RR Speaker (-) BLUE/GREEN
mikeys my herrrro
mytrukstilsux
i ended up figuring it out.. the wiring's weird but it works for now so i dont mind.
the only problem is my truck didnt have negative wires for the rear speakers, any suggestions on how i could run some?
