any bass heads?? post pics of ur systems
lapresa7
Im about to start redoing my system and just curious to what set up others are running
Im a bass head and there seems to not be alot of room for a big system in my truck, im thinking of jus using up all of the space in the extended cab
kam
thats what I did
N
norcallumps
I was a basshead back in the day. In my regular cab 'dawg I had two 12" kickers each in 2c.u. box. I ran a Phoenix Gold M50 bridged 2ohm mono. Highs were second hand Clif Designs 6.5" mid range/mid-bass and tweeters then some pioneer 4" all Powered by a Pioneer M50 or something like that. A Phoenix Gold x-over handled frequencies and a Eclipse 5301 controlled it all. On D.B. drag racing i did 140. Not bad for only 150 rated watts!
My buddy had a s10 with a walk through. (3) 18" Rockfords on a Phoenox Gold MS2125 along with a lot of components. All had passive x-overs. He built it for sound Q and did very well. The 18"s were just for wow factor.
h2omelon(nick)'s avatar
h2omelon(nick)
My little setup in my old B2600i.
lowlyfe's avatar
lowlyfe
You have PLENTY of room to build a killer system in the ex cab section if you wall it... I know a guy that has 4- 15" T1's in his S10 Excab and that thing crazy.
Here's my setup, not in a mazda but a bagged TBird. Im still working on it but our Mazda build has kept me from working on it.
I also have a SA12 on a T1000.1bd in my grand Cherokee tuned @30hz and it beats the block down, it's not really picture worthy though.
lapresa7
Those are some pretty cool set ups you guys have!
The current set up im running are 3 12s in a sealed box with a 1500 watt amp, im planning on going way bigger maybe 3 15s in a ported box each powered by a 2k watt amp, i already ordered 2 xs power batteries and another for under the hood, also researching on what alternator would be good to run with the new set up
hunterw's avatar
hunterw
Before my black truck was bagged I had 3 15s in it. And 18, 000 watts. Spl was my goal. Im about to build a new box for my white truck. Just 2 12s and 2500 watts. Ill post some pics in a minute
