Northeast \  Need help setting the timing
Northeast Events
views 2327
replies 2
millythemazda   +1y
i have a 91 Mazda B2200 cab plus. i pulled the engine tore it all down and rebuilt the entire engine. the only thing im reusing is the block and crank, everything else is brand new. I'm just having trouble figuring out how to set the timing when putting the belt, gears etc. back on.
Cusser   +1y
These should help. See
wrench   +1y
True story!!!
One of the easiest timing belts I have done. Just make sure you do the rotation at least 2 times to make sure the timing is set properly. Good luck!
