finally got the bed on!!
8
89dueceduece
ok heres the deal im wanting to start off fresh by going back to a stock frame i found a 86 cab plus truck like mine but before i buy the truck i wanna find out if there is anything that will keep me from swapping out cabs and motors
Post was last edited on Jan 07, 2009 01:21. Edited 1 time.
sleepyspeed's avatar
sleepyspeed
is your 89 efi? other than the fuel line difference of efi and carb, I think it should go right on.
8
89dueceduece
im not really sure but would i be able to use the fuel lines off of my truck and put them on the 86??
nytrdr24's avatar
nytrdr24
as long as they both have the same engine & tranny's then yes they ought to interchange, if one has a b22k engine, and one a b26k, then you might have issues with the tranny & engine mounts, also might have an issue if they both have the same engine & different trannys, but stuff like that & fuel lines should swap from one truck to the other no problemo....
8
89dueceduece
thanks for the help guys the other truck is a b2200 so hopefuly everything swaps fine
