Page 1 of 3
Mazda Projects \  Ponts rebuild
Ponts rebuild
Mazda Projects
views 4218
replies 24
following 11
pont   +1y
Whats up guys been a long time since I posted thought I would bring up to date on my truck. Just in case you did not know or don't remember here is my truck.
ALL PICS ARE CLICK-ABLE
This is my plans for it one day soon I hope.
Any way about July of 08 I let my little brother use my truck and lets just say when I got it back it was not right. This is what I pulled out of the engine number 2 rod bearing
I put anther bearing in it and drove it till Jan of 09 then the number 1 went bad to. So I parked her in the basement (my shop). At the end of August I started getting ready to rebuild the engine.
This is what number 1 rod looked like
New pistons
Since I had the motor out figured might as well paint the wheel wells
Block with a fresh coat of paint.
new brass core plugs
Valve cover clean.
Painted Valve cover
and Oil pan
Engine almost done.
engine bay almost put back together
Thats it for now there are lots more pics on photobucket if you want to look more.
skrapinsask   +1y
Looks like you will have a clean well running truck to start your project with
GL
paparoach1983   +1y
heck yeah man love the pics
toddluck   +1y
this is the same truck you replaced one of the rod bearings in?
pont   +1y
Yep
baha   +1y
Looks good man I love the fresh paint
pont   +1y
Well today I had a set back I busted my dist housing so now I need a new one. sucks but it happens.
toddluck   +1y
i may have one ill look tonight
paparoach1983   +1y
dam taht sucks bro
pont   +1y
Got a new one for 35 bucks shipped to my door now all I need is motor mounts, pilot bearing muffler, High flow cat, carb and some Time-sertsfor the header bolts. Then I can get this thing running again.
