Mazda Exterior \  5 Stud conversion up front
Mazda Exterior Mazda Tech
views 3658
replies 10
following 7
lydowt   +1y
Im looking for a stock part swap to do a 5 stud conversion on my 84 b2000, does anyone on here know of a way to do it?
paparoach1983   +1y
I DONT MEAN TO BE THE DEUSCHE BUT ON THE TOP RIGHT OF THE SCREEN IS A SEARCH FUNCTION WHERE YOU TYPE IN 5 LUG AND IT WILL BRING UP ALOT OF POST BY OTHERS ABOUT THIS YOU MAY FIND AN ANSWER THERE.
dvsdev   +1y
I looked at doing it myself and the guy at the local brake place said it was possible to just buy new blank discs off the shelf and have them drilled fairly cheaply, supposedly the front is that easy to do.
lydowt   +1y
so i found a way to do it, using different spindles and changing the lower ball joint over
v8xcab   +1y
DEUSCHE=douche u called him a German! lol
hunterw   +1y
Hmmm I think a 81 yota axle would fit tits in the rear. As far as the front I'm not to sure on the 84s. But I would think same concept. Redrill upper ball joints and you might be able to use the stock mazda lower ball joints
hunterw   +1y
And just use thee whole 84-95 yota spindle.
cmiller_10   +1y
na german in german is deutsch but thats ok.lol im only half.lol
lydowt   +1y
your close mate, the early lux diffs would swap over easy enough or the rear could just be re drilled which is no hassle. But ive opted to go for a series 5 or 6 RX7 full independent rear which will be used to provide me some easy camber in the rear and also eliminate articulation of the diff head through the motions of travel when using the rear bags. Up front all i had to do was swap over the lower ball joint from a lux aswell as the spindle assembly ive choosen to modify my steering to suit the front steer portion of the setup but you could just mount the spindles on opposite sides so that their wouldnt have to be any major mods for steering to work
cmiller_10   +1y
on airbagit.com they have a spacer that swaps. but they are 90 a piece plus shipping.
