Mazda Interior \  Dash Lights No Work
Dash Lights No Work
Mazda Interior Mazda Tech
views 2050
replies 9
trplezro   +1y
They came on for about 5 minutes right after I started the truck. Fuses are all good, unless there's another hidden panel somewhere. But the only one I saw was under the hood on the drivers side.
I checked the wires underneath the dash the best I could and everything seems to be fine. All my other lights work as well.
Any quick ideas before I have to test everything?
808hawaiian   +1y
DIMMER SWITCH?
trplezro   +1y
Messed with that and checked the wiring to it. All seemed fine.
trplezro   +1y
Also it worked for the moments the lights worked
808hawaiian   +1y
check ur bulbs?
toddluck   +1y
it is the dimmer switch man
use a jumper wire find the hot wire and jump it the light wire easy way to test for sure but id be willing bet thats the problem
trplezro   +1y
I had a feeling it was the dimmer.
My hazards also don't work. Fuses are all good. I know the hazards are a little module, signals still work. I'll probably have to tear into the truck this weekend. I may just try and bypass the dimmer since it's usually just a voltage regulator
toddluck   +1y
the hazzards are on a differant system
you have a blinker relay and a seperate hazard relay
dzminiz   +1y
I had mine go out one night, along w/ my running lights, kept blowing the fuse, come to find out, my drivers side corner lamp, the metal light pole in the back, was touching the fender, and grounding out.
trplezro   +1y
You were right todd, dimmer switch. I pulled it out and bypassed it and they work fine. Thanks again.
