Mazda Engine Swaps \  FE Motor into 89 B2200
views 1354
replies 2
rockinw   +1y
Looking to buy a JDM FE motor that is complete and install it into my 89 B2200. What other parts am I going to need to make this motor run. I assume I will need another ECU. What should I be looking for? Should I just pull the intake off and make it a carb since I already have a Weber on my orginal motor now.
themdot   +1y
Check out the search option I know this has been discussed a bunch on here. I'm under the understanding thats its quite a bit work/ headaches but def. possible. I wish I could tell ya what you needed but I honestly have no clue. Nice to see another bscener from central florida. Welcome!
mazdamandan   +1y
a jdm fe3 will not just bolt in. they are set up for fwd. it can be converted but it is easier and cheaper to get the kia sportage fe3n 95-up in that body style.
the dissy sticks out into the firewall otherwise, the kia is newer, less mileage and cheaper usually, the intake is one of the best parts of the system, keep it!! you will need the ecm and harness too, check out solomiata.com
