Trans-Dapt motor mounts
canucksfan1
Just wondering if any knows if the universal cross member/motor mounts the trans dapt make would work ok to drop a 350 in my lil b2200
maz2low
You can use the stock transmission crossmember in the mazda just need to weld holes shut and then redrill about 1/4 forward. As for motor mounts, jegs sell a set of tubed V8 mounts that take old GMC truck style mounts you just bolt onto motor lower it down until tubes hit topside of frame. Mark off and cut so they will slide down between frame rails. After that just weld in. Really really simple.
I made my own mounts out of 2x2 box tubing and steel plate, but they now have tons of universal mounts in Jegs/Summit racing catalog.
Related Discussions in Mazda Engine Swaps
