Mazda Engine Swaps \  mini spool
mini spool
views 3566
replies 11
jonnyboy303   +1y
hey does anybody know if we can put mini spools in our rear ends or do i have to stick to a welded diff? im putting in a 302 for drifting and need something to lock the rear end up. welded diff just sounds easy but also feel i can break shit more easily. lmk what u guys suggest or have.
vajr86   +1y
could you replace the rear end with something more strong that can handle the power and have a variety of diff locks??
jonnyboy303   +1y
For now I'm on a budget build ha I a bed on keeping the stock rear end for awhile.
vajr86   +1y
Then weld her up!! And put hard tires on for no traction. Lol
anguswilly   +1y
If you weld it and have any sort of sticky tires you WILL break axles. ALOT. Ask me how I know.
My 5.0 S/C setup had a B2600 rear axle and FD LSD in it and is still going today after 5-6 years abuse on big sticky tires. My new turbo truck has the same rear end now.
jonnyboy303   +1y
Well I plan on using junkyard special tires lol a lil harder to find 14's out here so. And is it worth the LSD? Is gonna hold a drift well enough though? That my biggest concern. And also how much is a rebuild for a FC LSD? Anguswilly how did u wire ur 5.0 setup btw?
anguswilly   +1y
If you are purely drifting and not much street - AND you are gonna use old, hard tires - then weld it - I did find that the FD LSD drifted well but (because it's a torsen) it worked better the more power I had - which means before I added the S/C to my 5.0, it would sometimes unlock in a corner
anguswilly   +1y
If you want, I have a RX-8 lsd for $200 shipped.
