rotary swap on a b2200 93
repu
i am trying to instal a rotary engine in my pick up the engine came from a 85 gsl se 13 b with manual trany i instal the transmition support to the stock place in the front i cant lower the engine the direction rod is there , my question is do you cut the o
befarrer's avatar
befarrer
I have an 86, so my oil pan may be different, but my engine is sitting higher in my truck then the stock motor (if you measure the crank height). I am using stock rear sump pan and my steering rod is about 1/8" away from my pan. The rod does not move up and down with suspension, just forward and back with steering about 2-3", the furthest back is when steering is straight.
repu
tanck wou for the quick response . i kep the same o
befarrer's avatar
befarrer
I am running completely stock brake setup, so I cant help you there, but here is a recent article:
Related Discussions in Mazda Engine Swaps
