Still having issues with the b2000
X
xtomx
hey guys just need some more suggestions, prior i had issues with my b2000 with it not starting while it was hot. turns out i just put up with it and figured out if i sprayed brake cleaner under the cap itd start up. so finally the past couple days i got into it and pulled out the pickup under the rotor. sure enough the wire was torn and very corroded. so i replaced it along with the lignitor. now it wont start at all... now basically its a new distributor with the cap, rotor, pick up, ignitor, wires, plugs, coil. AND set the timing (checked twice). ANY IDEAS WHATS UP...
thanks!
newbiet's avatar
newbiet
check that you have voltage at the coil positive, could be bad electrical portion of the ignition switch.
