Mazda 2.0L \  list of issues i need of help conquering.
views 1483
replies 7
kingdubs   +1y
86 b2000 se-5
today i put on a timing belt, igniter, plugs, and cleaned a few things up.
after installation and cleaning. it started and ran til it warmed up and then died out... afterwards it would restart momentarily and instantly die. which i believe is a issue with the ignition. now it has a spark issue, the coil had been hooked up wrong and still not sure if i have it right. anyone have a list of what goes on + and what on -? i am getting spark out of the coil. and a very very small amount out of the plug wire. when you test the coil with a test light on + it stays lit! and i took the new igniter out and no matter where you test it, it give a constant 1. ohm
when it was running it sounded great no ticks no click a lil smoke but it was just burning out excess crud. been parked now for sometime i assume bought it last week for 500 bucks and figured id throw my talents at it. but everyone needs help from the pros now and then!
Post was last edited on Sep 09, 2012 09:09. This post has been edited 1 times.
fearce   +1y
only thing i can tell you bro is this i got the same prob and only thing i do i cut it on and hold my foot on the gas for 30 secs not hard just a small amount until the gas runs through and gets a little warm. tap on the gas a few times while doing it.. it should idle maybe rough but idle if not you might have the wires wrong or you battery might be a little almost dead or weak. im not an expert thats just how i have to do my truck
sincitylocal   +1y
If your coil was hooked up backward, it would not run... I wouldn't worry about it, at this point.
Look at your ignition switch(electrical portion) as a possibility.
When they go bad, the often exhibit the very same symptoms you described.
kingdubs   +1y
i replaced the coil, check my wiring with the haynes, and did the jump with a fuse and it ran like a dream. so it is the ignition switch. anybody selling one? instead of rebuild i'm going weber. 32/36 or 38 unsure what ill pick.
sincitylocal   +1y
Most autoparts stores sell the switch.
People who have used the Weber 38 have suggested that it would have been better to use a 34/34.
kingdubs   +1y
webercarbsdirect.com shows the 32/36 is the kit for the b2000. k675.
for 269
kingdubs   +1y
is it possible to clean the points in the ignition switch? even worth it? i mean the cheapest switches i can find are like 80-90 bucks. budgets a little tight for that!
kagroat   +1y
Anybody know which wires goes to pos and neg at the coil?
There are striped yellow ones, striped black and white one, blue wire, etc.
thanks
