Mazda 2.0L \  81 b2000
81 b2000
views 1024
replies 1
following 2
81b2000   +1y
hey guys i have a 1981 mazda b2000 and the other day i started it to warm it up. it ran for about a minute then died no spark so i replaced the coil and still wont start . no spark while turning over but when you turn ignition off it sparks once off the coil wire i am stumped and need help asap thanks
sincitylocal   +1y
With the key on, check for power at the coil.
If there's not 12 volts on the positive side, your ignition switch may be bad.
edit: If there are contact points in you distributor, they may be out of adjustment, welded closed, or just worn out.
