Mazda 2.0L \  Electrical problems
Electrical problems
views 1054
replies 4
following 5
67eleanor   +1y
Hello, I have an 84 Mazda SE-5 2.0l and I'm having a few electrical problems. My tail lights, dash lights, radio(stock), heater fan, dome light, and gear selector light all don't work.
Has anyone else had these problem??? if so how did you fix them?
thermus   +1y
There is a new site in town and they have an electrical request section.
Sent from my Galaxy Note 2
87forever   +1y
Not fluent with your year but some ideas.The tails may not work due to the brake light switch at the pedal itself.Unless another wiring problem is present.The dash and shifter light I would lean maybe towards the dimmer switch(do you have one).I would check the obvious like fuses and check your dome light socket for the bulb arching or your door switch in the jamb (door area) for a bad ground.Just a few ideas and I am super tired.Maybe off the mark on all the above but,some ideas.
jacob_tamblin   +1y
the dome lights, radio, etc are on the same fuse in later models. Hopefully that helps.
mazdafvr   +1y
check the "room" fuse in the inside fuse box, will keep power from almost everything inside cab if its blown.
