Mazda 2.0L \  NO POWER in upper rpms!
views 909
replies 9
swampdonkey   +1y
Truck runs like a champ at idle and and when half on the throttle. But if you try to run it to upper rpms it falls on its face and has not power! I mean Its a struggle getting around town and if there is a hill in the road. Forget about it whole lotta down shifting and lose lots of mph before I make it to the top. Hell I cant even spin tires in gravel... I have owned many mazdawgs and have never experinced this. Please Help!
Things I have tried to fix it. I swapped carbs because I thought mine was bad, nope still the same problem. Replaced the plugs, Wires, cap, rotor, fuel and air filter.
swampdonkey   +1y
I was thinking maybe a clogged converter but I have plenty exhaust pressure coming out.
swampdonkey   +1y
Also does anyone know where the wire to the electric choke goes?
cab+rider   +1y
The electric choke wire connects to the rear of the alternator a single wire lead to a recessed hole. On your performance issue did you recheck your firing order of the distributor cap?
swampdonkey   +1y
WOW! Ok let me get this right... The firing order is 1,3,4,2 correct? 1 is at the very front of the engine and the 4 cylinder is closest to the firewall correct? and at 9 oclock looking at the cap is the number 1 cylinder correct?
swampdonkey   +1y
The reason I ask is because the previous owner had 1 cylinder closest to the firewall and i swapped everything and it wont start now...
swampdonkey   +1y
HOLY SHIT! All of the timing is wrong! How the hell did this thing even run?
Cusser   +1y
Apparently someone had the distributor body lined up OK, but I bet thew distributor rotor was installed while NOT at #1 TDC.
You need to line up the crankshaft pulley at #1 TDC (make sure it's at #1 TDC, and not at TDC #4 which is a full revolution off), pull the distributor out, and re-install with the rotor pointing to the 9 o'clock position when it's in TDC #1. Re-install the distributor cap with the wire for #1 over that 9 o'clock position going to the forwardmost spark plug, and so on, towards the rear.
See for a nice diagram of spark wires and TDC.
swampdonkey   +1y
Thanks Cusser! I found that link also thats how I figured it all out thanks!
cab+rider   +1y
GOOD SAVE THERE CUSSER!!
