Mazda 2.0L \  new motor, was running good & died
views 758
replies 3
tony nash   +1y
I have no fire,what is the little black box w/single wire going to dist, mounted on top near valve cover, what does it control?
TNash
dan woodland   +1y
Sounds like the noise suppressor... Truck needs air, fuel and fire; check your coil after verifying you have no fire. If you have no fuel try your fuel filter.
tony nash   +1y
I was wrong, the wire from the "noise suppressor"goes to + side of coil. I have fire to coil w/key on, doesn't seam to be firing at plug. got gas.
how can I check distributor?
87forever   +1y
Could be your ignition module in the distributor is bad.Not saying this is the problem but the ignition where your key goes could be faulty!Try jiggling it or in small increments to see if it tries to fire.Tired I am but some ideas in the mix.
