Broken sensor?
Broken sensor?
griffingra
While installing a new head gasket in my son's '86 B2000 I discovered this item that looks like a sensor with the electrical connection broken off. It is under the intake manifold even with the back edge of the carb. I'll try to get a better picture that can bee seen...
There is a lead that looks like a temp sensor, but it doesn't fit into the opening of the sensor in the picture. [edit] I figured out that the lead was wrapped around part of the sensor, and then encased in plastic...
I assume one of these is the reason the temp gauge doesn't work?
The joys of buying a used truck w/o a warranty...
Purchased wt608 sending unit...buzz... much smaller than the one in the bottom of the manifold. WT608 sending unit is about 12mm across with an 8mm x .7 thread. Unit in manifold is 19mm across with about (guessing) 14mm thread.
Post was last edited on Apr 15, 2015 04:16. Edited 1 time.
dan woodland's avatar
dan woodland
Looks like the temp sensor to me... that's what it looks like when it pulls out of the threaded brass.
griffingra
I believe it turned out to be a TS15. Not what an 86 should have. but now the gauge works.
