Mazda 2.2L \  HELP!!
HELP!!
views 1189
replies 6
futrao   +1y
ok i got a power coated valve cover the other day so i swap the all one for this new one and when i try to start the engine my truck started making this tickin anoying noise
any ideas what could this be?? a rocker/hla, lifter? any help would be great
futrao   +1y
here is the link sorry
toddluck   +1y
cant see utube from work but how long was the old valve cover off?
rabbit636   +1y
Did you torche the bolts to spec? If you over tighten them the rocker arms will tap the valve cover. Maybe need a new gasket also if it is too compressed.
konzern1   +1y
lol i was gonna say aaaaah the good ol mazda tick before i herd the sound clip but that sounds worse lol
futrao   +1y
i didn't torque the bolt to spec, i probably over torque, cause i was ruuning fine with the old valve cover and i didn't toutch the rocker arm or anything i just swap valve cover and it started to sound like that i'll try and loose the bolts a bit tomorrow and see what happend, and if i beed a new valve cover gasket where can i get one? i kinda thought about the rocker arm hitting the valve cover
toddluck   +1y
take off the valve cover and see what its hitting
