Mazda 2.2L \  need bolt torque info
views 1182
replies 3
90-b22dawg [andrew]   +1y
head bolts should be torqued to? also what the valve cover bolts should be torqued to?
dzminiz   +1y
B2000 B2200 Engine w/ Timing belt
Cylinder Head Bolts - 59 to 64 Ft.-lbs
Misc.
6mm bolt - 5.8
8mm bolt - 13.7
10mm bolt - 27.5
12mm bolt - 47
14mm bolt - 66
sweet thanks...
carolinasled   +1y
Guys, Where is a good place to get the head bolts from? I have the gasket set and forgot totally about the bolts. Didnt know if you guys might have found a better deal some where.
Thanks Ryan.
