Changing motor oil!
Changing motor oil!
j-bird
just a question...... After draining the old oil and before you plug the pan back up. Do you poor some new oil thru and let it flush?
And then plug and poor!
badchicn (rick)'s avatar
badchicn (rick)
Uh...no. I do it like this.
1) Run the truck for a mile or two to get it warm.
2) jack up truck, place pan under drain plug and filter.
3) remove plug
4) remove filter
5) replace filter with new...don't forget to run a drop of oil on the rubber seal.
6) when nothing comes out of pan, replace plug.
7) Add new oil.
check level
9) run truck
10) recheck level, add if necessary.
11) Done....drink beer and lay under truck for an hour.
12) tell everyone you spent all day working on the truck.
jmzcustomz (jeff)'s avatar
jmzcustomz (jeff)
LOL I like the last few steps. I usually do run about half a quart through just to kinda flush it out. Kinda gets any particles that are so close to coming out but stop when the oil is out.
j-bird
Lol...11 and 12 are the way to end the day!!!
W
will
I also like to spray brake cleaner on the bolt to clean it off for a better seal.
nonamedsomebody's avatar
nonamedsomebody
That is how you change oil. So just adding 1-2 qts ever other week don't count as an oil change... J/K... Theses trucks burn oil like a coal train..
jimbeater's avatar
jimbeater
hahaha yeah there ya go... stay outta the upper rpm range and it wont burn as much... i do a 140 (km/h) on the hwy usually and thats rpms at almost 4000 i think... i need a liter of oil say 500 kms. fresh oil it'll stretch a lil longer seemingly.
i do the quick flush method once in a while also. not like its going to flush every area of the engine, but like stated it'll flush out the heavy loose gunk that felt like hangin around.
and at first i didnt know there was a plug... i just pulled the oil filter and ran the neo....er truck until it stopped spitting...
bigamigo's avatar
bigamigo
found this thought of the tod sorry buddy lol
OIL CHANGE INSTRUCTIONS FOR WOMEN:
1. Drive into Ultra Tune when the odometer reaches 10,000 kilometres since the last oil change.
2. Drink a cup of coffee , read free paper.
3. 15 minutes later, swipe the Visa and leave with a properly maintained vehicle.
Money spent:
Oil Change: $40.00
Coffee: $2.00
Total: $42.00
OIL CHANGE INSTRUCTIONS FOR MEN:
1. Wait until Saturday, drive to auto parts store and buy a case of oil, filter, kitty litter, hand cleaner and a scented tree. Swipe the Visa for $50.00.
2. Stop by the Bottle Shop and buy a slab of beer, swipe the Visa for $40, drive home.
3. Open a beer and drink it.
4. Jack car up. Spend 30 minutes looking for jack stands.
5. Find jack stands under caravan.
6. In frustration, open another beer and drink it.
7. Place drain pan under engine.
8. Look for 19 mm ring spanner.
9. Give up and use crescent wrench.
10. Unscrew drain plug.
11. Drop drain plug in pan of hot oil: splash hot oil on you in process. Curse and swear.
12. Crawl out from under car to wipe hot oil off face and arms. Throw kitty litter on spilled oil.
13. Have another beer while watching oil drain.
14. Spend 30 minutes looking for oil filter wrench.
15. Give up; crawl under car and hammer a screwdriver through oil filter and twist off.
16. Crawl out from under car with dripping oil filter splashing oil everywhere from holes. Cleverly, hide old oil filter among rubbish in bin to avoid criticism from greenie family members. Drink a beer.
17. Install new oil filter making sure to apply a thin coat of oil to gasket surface.
18. Dump first litre of fresh oil into engine.
19. Remember drain plug from step 11.
20. Hurry to find drain plug in drain pan.
21. Drink beer.
22. Discover that first litre of fresh oil is now on the floor. Throw kitty litter on oil spill.
23. Get drain plug back in with only a minor spill. Drink beer.
24. Crawl under car getting kitty litter into eyes. Wipe eyes with oily rag used to clean drain plug. Slip with stupid crescent wrench tightening drain plug and bang knuckles on frame removing any excess skin between knuckles and frame.
25. Begin swearing fit.
26. Throw stupid crescent wrench.
27. Swear for additional 5 minutes because wrench hit bowling trophy.
28. Beer.
29. Clean up hands and bandage as required to stop blood flow.
30. Beer.
31. Dump in five fresh litres of oil.
32. Beer.
33. Lower car from jack stands.
34. Move car back to apply more kitty litter to fresh oil spilled during any missed steps.
35. Beer.
36. Test drive car.
37. Get pulled over: arrested for driving under the influence.
38. Car is impounded.
39. Call loving wife, make bail.
40. 12 hours later, get car from impound yard.
Money spent:
Parts: $50.00
Driving Under Influence fine: $2500.00
Impound fee: $75.00
Bail: $1500.00
Beer: $40.00
Total: $4,185.00 ... but at least you know the job was done right!
j-bird
lol
mazdadropped
Shitty Buzz !!! lol def not the way to do things
