I have a 87 b2200 5 spd and it has carb. It drives fine until it gets up to operating temp but then it will start to misfise when its under load mainly in 3rd- 5th gear. Once it starts misfiring it gets worse and worse until i pull over. If i let it cool a little it will drive fine until it gets hot again. I checked the plugs and they looked good and the wires are new any ideas.
90-b22dawg [andrew]
sounds like the timing belt needs to be replaced. while your in there might as well change the water pump too.
sburnsy
o that sounds fun thank you
mazdatweaker
Do you have a timing light?
If you do, have you checked your vacuum advance?
Have you replaced your fuel filter? If you have a bad filter, full of water, that sort of thing, the engine is going to starve for fuel. . .it isn't as much of a problem while the choke is closed. Once it opens, more air needs more fuel.
Maybe a fuel pump is starting to fail.
You have described "something" under load.
But the word "misfire" is ambiguous.
The only thng I can figure out is that the problem is replicable.
It only occurs when the engine reaches operating temperature.
It probably isn't a plug.
Or a wire.
Or a timing belt.
Maybe it is a bad distributor cap.
hocbj23
or a coil breaking down under load when it gets hot.bj
