Mazda 2.2L \  Weber Carb whistles
Weber Carb whistles
views 4169
replies 7
following 6
tk-lv2kruz   +1y
I Have a weber carb on my 2.2 mazda B.. it started making this loud whistle sound like a loose belt.
when the engine is cold is perfect then sometimes is starts whistling and then it stops if i drive more than 1hr.
is really weird!
anyone have this issue before or know why this is happening??
midnightmike   +1y
The whistle goes wooooo woooooo!
Its like an alarm clock!
90-b22dawg [andrew]   +1y
vac leak
tk-lv2kruz   +1y
it sounds like when an alternator belt is loose, the sound is constantly.. I don't have a vacuum system
white trash renegade   +1y
you should still have a couple of vacuum lines on the motor
bagdb2200   +1y
My buddy's Weber was doing the same thing. It ended up being a vacuum leak between the adapter plate and the carb.
tk-lv2kruz   +1y
K here is another questions that maybe you can all help.
what voltage should the electric choke should be running?
mine is connected to the alternator which i think is find but is only putting out 6.5V
jrock4224   +1y
Its most likely the adapter plate....mine also needed the adapter plate port matched to carb and intake to get it to totally to go away...
