needed wiring
needed wiring
joehussey
Ok after a friend gave me what he called a weber, I have had all the mounts custom made. ( what a friend right!)
anyways its starts but then die"s. I was so excited to remove all the emission crap on the passenger side of the engine bay behind the battery. I feel that i may have removed something that was needed to control the spark. atleast that what it seems like.
to fix this i just want to rewire the egnition. is there anybody out there that can give me the run down of what is need to run this old dog.
you know just the ducks guts nothing fancy here. just needs to run and keep running
joehussey
also, there was a bunch of fuel lines that i just didnt understand. i plugged the one that is furthest to the passenger side. it seemed to be nothing useful to me. could it be causing a vapor lock?
paparoach1983's avatar
paparoach1983
well when you put a weber on all the stuff on the passenger wheel well is absolete e xcept what is attached to the wire harness that comes across the rad support post some pics of this such weber and we can help a bit there as well.
here is what we all call the mazda bible its got about everything you would need to fix the issues just start cross counting your steps
joehussey
thanks bro. i need to get this thing back up and running. it is my work truck so i need to go to work on monday.
ill get some pictures posted when i figure out how to resize them
