Fuel pump?
bmxdad45@yahoo.com's avatar
Fuel pump?
88mazdab2200's avatar
88mazdab2200
Started my truck tonight, got out and moved my wifes car. When I got back in my truck it died and now it won't run....it will start, but won't run. I would assume it's the fuel pump. How difficult (or not difficult) is it to change the fuel pump and where is it located? Sorry, I've always owned gm so I'm new to the 2.2 motor
blackhulk's avatar
blackhulk
hey if its standard it on the passenger side engine bay on the head...to the end of it by th firewall.......its its auto or fuel injected its intank
88mazdab2200
It's carburated 5 speed
blackhulk's avatar
blackhulk
its in the engine bay at the end of the head...passenger side....few bolts to undo it and the fuel lines also..replace the gasket...install...
E
emjay
don't assume that it's just the fuel pump. It could be a vacuum leak, a clog in the tank, a clog in the exhaust, a faulty or weak ignition coil. tell us more about the symptoms and what it was doing before it died. anything interesting happen to the truck leading up to this?
Z
zaccutt
Lol once again I'd say change you're fuel filter, cheap and easy and sometimes the problem. Its white and on the passenger side.
