so i have a question my truck doesnt idle and when i look at the sight glass there is barely any gas in it at all do i have to take the carb and knock that pin out before i can adjust it i can turn my idle screw either way and it doesnt change at all
readjust your float
stuartb
thats what im wondering how to do ive never done it
E
emjay
are you sure that your fuel pump is pumping fuel to the carb?
Z
zaccutt
Maybe start with your fuel filter?
binatang
I have a friend who is having close to the same trouble. Difference is, his truck runs perfect! But his filter only shows about 1/4 inch of fuel in it. He thought it was the fuel pump, so he bought a new one, and still the same thing. Again, it runs perfect!
drgnby
I am having the same prob with my truck will start but won't rev just bogs replaced pump filter and tried different carb but still same issue. Pump is pumping but sight glass has little or no gas in it so adjusted the float still nothing going to try electric pump and cross my fingers.
W
wood_butcher
I know this is an old post but thought I'd chime in. Mine was doing the same thing. Turned out to be a hole in the rubber fuel line right above the passenger rear tire. Mice had chewed on it. Maybe yous is cracked or mice made it into your truck as well.
